| if it was a turbo swap and they used an NA tranny then you'll need to verify the starter is properly shimmed away from the bellhousing (about 1/8") and if you're unlucky he probably didn't grind the bellhousing out to clear the TT flywheel.
*disclaimer*: all that I say may be true or I may be completely wrong and I accept that.... please, it is your duty as another person on the internet to impolitely tell me how wrong I am :) "The dreaded 2nd windshiled wiper swipe when you turn it off its almost like tis showing you that it's boss, and it doesn't have to stop when you tell it to :("-College Boy (discussion on ptu relocation) "No good reason to put it there anyway. -Bernie (NoVA) False -vorpalZ False. -Bernie (NoVA) You're correct, there are 3 good reasons -vorpalZ False. -Bernie (NoVA) Wow, right again, just remembered another, make that 4 -vorpalZ" XD
